1 - 10 of 10 Posts
Hey guys so I just set up my new Onkyo(NR818) and replaced my old onkyo (SR508).
My current setup is the martin logan motion 262:
2 motion 2 front speakers
1 motion 6 center speaker
2 motion 2 surround speakers
dynamo 700w sub woofer
It seems when I had this exact setup hooked up to my old onkyo(SR508) the volume level would typically be around 45 to 55. However, it seems with me new onkyo(NR818) I have the volume between 65 and 75 to achieve the same volume as the old receiver.
Is this normal?? I would think since this receiver offers more watts per channel than my old onkyo I would not have to turn up the volume as high, but the opposite seems to be occurring.
any thoughts??
thanks,
Brandon
Hi Brandon, did you run the Audyssey room setup yet?
Your levels are not uncommon as receivers now dont have a volume control that goes to 250% like the old days. If your at 85% of its maximum output that equates to about 65dbs (Reference level is 75dbs).
On the older receivers you rarely went past 1/3 of the volume knobs full rotation anything more than half was clipping the amps and just ridiculous. These days when you reach 100% or 0db on the display thats about the maximum that the receiver will go before distortion so thats where the limit is now placed.
No problem. Just to make sure, when you ran Audyssey did you place the mic on a tripod at ear level where you sit and do at least 4 position readings?
I did 8 position readings and I placed the mic on top of a bunch of stacked pillows (probably not legit) but they were at ear height
Ya, the pillows will affect the readings. I would defiantly get a tripod. Just a simple camera tripod nothing fancy.
I picked up a cheap mic stand at the local music store and it works great.
1 - 10 of 10 Posts
