do you need a s-converter to bump the lfe voltage up??
Help please:huh:
Help please:huh:
Posted via Mobile DeviceOh i see but theres a few ways i could do this from the receiver's lfe i could go the LFE to 1/4 route where from there i use a xlr to 1/4 and there xlr to the s-converter and from there another xlr to 1/4 to the ep4000
or
I could go rca fromn receiver to the rca on the samson and then xlr to 1/4 to the ep4000 which is the best way?
does any on have pictures for further clarification thanks
It appears your original queation was never answered. No sense buying anything until you know you need it. Just my opinion.do you need a s-converter to bump the lfe voltage up??
Ok so the rca that goes into the s-converter is a RCA to LFE im assuming anf the XLR's are going from the S-converter to the ep2500's cool look great..
Ok cost is and issue but not that big for 20 bucks
So whats the difference between the S-converter and the art box and wheres the cheapest place i saw 50 but some one said 30 idk where thought?
ANother side question why do you have both boxes?? looks like the S-converter (samson) would be fine for 2 amps right arent they input 1 and 2 i saw pics and one says cold and the other gnd whats the meaning sorry im such a questioner i just dont what issue in my first big build... im scared for the custom box!!!
Thanks SOOOOO much Josh your shackster winner of the year IMO and im sure many others too!!!
What's the prize???? :whistling:Thanks SOOOOO much Josh your shackster winner of the year IMO and im sure many others too!!!
I was once in your shoes..... to avoid using more equipment/connections when I added my Samsom to power my fronts, I just bought a pro-amp with RCA connectors, all you do is connect from AVR pre-out to pro-amp and you're done (pro-amp will convert/match the voltage):innocent:Ok so the rca that goes into the s-converter is a RCA to LFE im assuming anf the XLR's are going from the S-converter to the ep2500's cool look great..
