I understand your logic David but unfortunately the ep4000 doesn't offer that s-converter is a guy thing to have too.
Cheers,
KrazyBassKevin
Cheers,
KrazyBassKevin
You're right, there's a lot of pro-amp (including ep4000) that will require the converter to work the way is supposed to work, I was just saying that if others want to avoid using more equipment/connections just to look for pro-amps or external amps with RCA connectors.I understand your logic David but unfortunately the ep4000 doesn't offer that s-converter is a guy thing to have too...
Are the Kickers wired separately or are they wired together?i think 2 separate?
For a music sub as shown in the model above they'll never take 550 watts. They'll bottom out long before that.i was wondering about running 550 to them on 8 omhs non bridged
You previously said the Kickers were for music and you were getting a Fi Q for HT. I'm lost.Well this is not only for music its for a HT sub as well
