Onkyo TX-NR1007, TX-NR3007 and TX-NR5007 THX™ Ultra2 Plus™ Certified 9.2 Channel Network Receivers: Official Thread
TX-NR5007
Top-of-the-Line Networking Powerhouse Sets the Standard
As Onkyo’s flagship model for the network generation, the TX-NR5007 offers a mouthwatering feature set designed to satisfy even the most demanding home theater purist. The expanded 9.2-channel configuration allows you to enjoy multi-zone playback as well as the latest surround formats by Dolby, DTS, and Audyssey. Advanced networking capability, meanwhile, enables you to incorporate PC-based audio and internet radio into your home theater set-up. Video signals fed through this receiver get the luxury treatment, thanks to HQV Reon-VX processing, ISF calibration, and 1080p upscaling of all video sources via HDMI™ 1.3a. In the engine room, the TX-NR5007 boasts an impressive array of audiophile-grade components, including large, customized transistors to drive high currents and 22,000 ?F capacitors to support a huge and stable power supply. Add to that high-quality 32-bit Burr-Brown DACs; ultra-low-jitter circuitry; and independent power supplies for amp, video, and audio circuitry, and you have a networking powerhouse equipped to deliver an immaculate A/V performance every time.
Special Features
Front L/R = 145 W + 145 W (8 ohms, 20 Hz–20 kHz, 0.05%, 2 channels driven, FTC)
Center = 145 W (8 ohms, 20 Hz–20 kHz, 0.05%, 2 channels driven, FTC)
Surround L/R = 145 W + 145 W (8 ohms, 20 Hz–20 kHz, 0.05%, 2 channels driven, FTC)
Surround Back L/R = 145 W + 145 W (8 ohms, 20 Hz–20 kHz, 0.05%, 2 channels driven, FTC)
Front High/ Wide = 145 W + 145 W (8 ohms, 20 Hz–20 kHz, 0.05%, 2 channels driven, FTC)
Dynamic Power
400 W (3 ohms, 1 ch)
300 W (4 ohms, 1 ch)
180 W (8 ohms, 1 ch)
THD (Total Harmonic Distortion) = 0.05% (Rated power)
Damping Factor = 60 (Front, 1 kHz, 8 ohms)
Input Sensitivity and Impedance = 200 mV/47 k-ohms (Line) 2.5 mV/47 k-ohms (Phone MM)
Output Level and Impedance = 200 mV/470 ohms
Phono Overload = 70 mV (MM, 1 kHz, 0.5%)
Frequency Response = 5 Hz–100 kHz/+1 dB, -3 dB (Direct mode)
Tone Control = ±10 dB, 50 Hz (Bass) ±10 dB, 20 kHz (Treble)
Signal-to-Noise Ratio = 110 dB (Line, IHF-A)
Speaker Impedance = 4 ohms–16 ohms or 6 ohms–16 ohms
Downloads (Manuals and Firmware Updates)
[img]http://www.onkyousa.com/images/common/product_images/Receiver/TX-NR5007(B)MDC_FR.jpg[/img]
TX-NR5007
Special Features
- THX Ultra2 Plus certified
- HDMI V1.3a repeater (8in (1 front)/2out (simultaneous), 1080p compatible)
- HDMI 1080p upscaling powered by HQV Reon-VX
- Dolby PLIIz Processing
- Dolby Volume
- Audyssey DSX Surround processing
- isf Video Calibration
- Component Video Upscaling (up to 1080i)
- Front and rear USB inputs
Dynamic Power
