1 - 1 of 1 Posts
http://www.frys.com/product/6320111?site=sr:SEARCH:MAIN_RSLT_PG
ONKYO TX-NR1008 9.2 CH
9.2 HOME THEATER RECEIVER
Mfr: ONKYO Model: TX-NR1008
FRYS.com #6320111 UPC: 751398009365
The TX-NR1008 is an upper-mid-range A/V powerhouse designed to give you maximum set-up flexibility in the home. Its 9.2 speaker channels let you enjoy a multichannel source in your main room, plus powered audio in two other rooms. Or you can use the extra channels to take full advantage of the new surround dimensions of Audyssey DSX™ and Dolby® Pro Logic® IIz. Other processing highlights include DTS-HD Master Audio™ and Dolby® TrueHD for pristine lossless audio on Blu-ray Disc, and HDMI upscaling of all video sources to 1080p with Faroudja DCDi Cinema™. As a network A/V receiver compatible with Windows® 7 and DLNA, the TX-NR1008 lets you stream audio from your PC or from internet radio channels such as vTuner and SIRIUS. Set up and calibration are easy and accurate, thanks to ISF video calibration, a new overlaid graphical on-screen display, and Audyssey room correction and equalization. Bi-amping capability and a smorgasbord of the latest connections complete what is an outstanding entertainment package.
Shipping: Unavailable
Notify me when product is available
Store Pickup: Check Availability
While supplies last
Detailed Description | Tell a friend | Warranty Info
larger view
Price: $ 1,299.90
Other Categories with this or similar products
Frys» Audio» Home Audio & Speakers» Receivers, Amps & Tuners» Receivers» 7.1 A/V Receivers»
(Manufacturer # TX-NR1008 )
FEATURES
?Seven 1080p capable HDMI inputs (V1.4a repeater) including 1 Front with 2 outputs
?THX Select2 Plus Certification
?isf Certified
?HDMI 1080p video upconversion by Faroudja DCDi cinema
?WRAT technology and discrete amp construction for cleaner sound
?TrueHD/DTS-HD decoding to support the latest Blu-ray technology
?PC Input
?Front-Panel USB Input for Memory Devices and iPhone®/iPod® Models (Enables Display of Album Artwork)
?Optional iPod Dock / HDradio module via U.Port
?4 DSP Gaming Modes: Rock, Sports, Action, and Role Playing
?Audyssey MultEQ w/ Dynamic EQ & Dynamic Volume>
1 - 1 of 1 Posts
