I bought a TX-NR3007 this fall. Love it.
It was connected to my 7.1 system (Klipsch Reference and SVS PC12+ sub) from the start with no issues.
Last week, I bought a used PC12+ to complete my 7.2 system. I connected the used unit to the Sub #2 pre-out on the AVR. I noticed that when I turn the AVR volume up and down, I can hear a faint clicking noise from Sub #2 channel. It is very faint, but noticeable when there is no other sound in the room. Thinking it could be a problem with the used sub, I swapped the two subs (so now my original sub is connected to Sub #2) and can still hear the clicking from that channel.
I did some troubleshooting:
  • Same result whether IR repeater is connected or disconnected.
  • Same result whether I use remote or knob on AVR to adjust volume.
Should I be concerned?
Anyone else experience this issue?
Any possible remedy that does not involve sending the AVR back for warranty service?
Thanks,
sga2
I know when i run test tone CD's at high volume i can hear a clicking sound from the mains, i've heard it on my car audio systems as well but never came to a conclusion as to why it does it.:dontknow:
For what it's worth, I hear the clicking sound when there is no program material (i.e., as I turn up the volume waiting for the BluRay to begin).
sga2
I would connect sub #1 ONLY to that sub 2 output, leave sub #2 completely disconnected. Still have clicking, its not sub #2.
Discussion Starter #5
I'll try that and report.
For clarification, from now on I'm going to refer to my original unit as Unit A and the recently purchased unit as Unit B and the two sub pre-outs as SW1 and SW2 (as they are labelled on the AVR). To clear up any confusion:
When I connect Unit A to SW1 and Unit B to SW2, I hear clicking from Unit B only.
When I connect Unit B to SW1 and Unit A to SW2, I hear clicking from Unit A only.
Thanks,
sga2
Discussion Starter #6
UPDATE:
When I connect Unit A to SW2 and disconnect Unit B altogether, I hear clicking from Unit A.
Also, I noticed that the clicking occurs when I have a BluRay playing, but goes away when I stop or even just pause the movie.
