1 - 7 of 7 Posts
HTS Reviewer
Introduction
There has been a lot of news this year related to AV receivers - major new technologies, questionable changes in room-correction features, and big brand partnerships. Onkyo seems to be right in the middle of all of it. The company began releasing updated models to it's TX-NR line of networking surround sound receivers. Confirmation of Dolby Atmos capability and the loss of Audyssey immediately sparked debate and speculation throughout the home theater enthusiast community. While some find the thought of an Atmos capable home theater thrilling, others consider the absence of Audyssey a complete deal-breaker. Beyond these major developments not much has changed, and the TX-NR737 performs as you would expect any other Onkyo AVR to perform.
Design, Build Quality, and Aesthetics
The NR737 is a 7 channel receiver with the usual assortment of HDMI inputs, music streaming apps, multiple zones, 4K video processing, HD audio decoding and automated room-correction. It boasts THX certification (Select2 Plus), compatibility with HDMI 2.0 and HDCP 2.2 and network remote control via mobile device. Onkyo has utilized a high current torroidal transformer and its Wide Range Amplifier Technology to produce 110 watts per channel at 8 ohms. Among the first to feature Onkyo's new in-house room correction, the NR737 is equipped with AccuEQ, which replaces Audyssey MultEQ XT in the outgoing NR727. Another first for Onkyo is the inclusion of Dolby Atmos capability. The NR737 is currently the lowest model in Onkyo's lineup to offer this feature. I'll be skipping Atmos for this review, since the firmware update is not yet available and my Atmos in-ceiling speakers are still in their boxes. (stay tuned for an HTS review of a higher level Onkyo with Atmos)
The TX-NR737 feels nice and sturdy. It is noticeably bigger and heavier than the 626 I reviewed last year. As expected the chassis and shell are black-painted sheet metal, and the faceplate is plastic with a brushed metal texture. All of the knobs and buttons on the front of the receiver worked smoothly and reliably throughout the review period. All of the speaker outputs, RCA jacks, and HDMI ports on the rear of the unit held connections firmly and and also worked reliably. Overall I would say the construction quality of this unit lines up well with my expectations for a receiver in this price range.
Although I try to avoid giving aesthetics too much weight in my decisions to buy audio electronics, but it is certainly a factor for most people, and something I always take note of. In general I like the looks of Onkyo's current AVR lineup due to the simple and clean design. I like the brushed metal look as always. The single large knob for volume keeps things clean and functional, though I tend to prefer the function and aesthetics of two symmetric knobs - one for volume and one for input. The display panel is large and clear enough to read from across the room if needed. The color and design of the display are pretty standard and should blend in well with other AV equipment.
Setup and Operation
Connection and startup of the NR737 is no different than most other AV receivers with HDMI connections. I used four of the HDMI inputs and had plenty to spare. This receiver can process and output up to 7.1 channels in a few different configurations. I tried two variations of 7.1 (5.1 + back surrounds, and 5.1 + front heights) and decided to use 5.1 + front heights for the majority of the review. This is completely a matter of personal preference, but does require some configuration in the speaker settings either way. Speaker connections are simple thanks to 5-way binding posts and speaker wire labels included with the receiver. The labels, while not necessary, are quite handy in my opinion. I also chose to connect the Onkyo to my network via CAT-5 cable for firmware updates and Spotify streaming.
Once all of your connections are made and you're ready to power the receiver on for the first time, you have three options. Option one: automated room correction via AccuEQ (you will be prompted and guided through this if you choose it). Option two: skip AccuEQ and manually set speaker distances and volume, and add external EQ for subs, etc. Option three: skip it all and get straight to watching football! There is no wrong choice here, but room correction is generally recommended as a super easy way to compensate for irregular room shapes and/or speaker placement. This can be achieved manually to a certain degree with a tape measure and SPL meter. I would personally not recommend option three, but if you room setup and speaker arrangement are already close to ideal for your desired surround format, then you may not be missing out on too much by skipping calibration.
I typically choose the manual option first followed by some critical listening with music and movies. If I feel like the experience could be improved more, I'll run the automated calibration program (if available) and let my ears be the judge. Having said that, I wouldn't call this a fair and thorough review if I skipped over room correction... so here are my thoughts about my first experience with AccuEQ.
It's super easy to setup and run. If you do happen to skip it the first time you powered on the receiver, you can start the process at any time by simply plugging the microphone into the "setup" jack on the front panel. It will begin by asking you a few questions about your speakers, and if you have a subwoofer, and off it goes. Whether or not you have used something like this before, it's a breeze. Once it starts, the process takes about two minutes, maybe three. I made a note of my manual calibration settings so I could compare before and after AccuEQ. Since there is no manual EQ, my comparison is somewhat limited to speaker distance, level, and crossover. Here is the data:
No code has to be inserted here.
Now, on to the results. Measured frequency sweeps of the front right channel confirm statements that AccuEQ does not EQ the front channels. The graphs were identical with AccuEQ turned on and off. So a comparison of response out of the box compared to "corrected" is basically irrelevant for the front channels. Instead, I compared my manual settings to the post-AccuEQ settings to compare the level calibration and crossover settings.To see how effective the EQ was, I took a look at the front right height channel instead (graph 1). To get an idea of how well the EQ filters worked on the other channels, I compared before and after sweeps of the front right height channel (graph 2). Finally, for reference, I compared all four, to see if AccuEQ was trying to match the response of the surrounds to the un-filtered response of the mains (graph 3).
Measurement Graphs
*Quick disclaimer - kind of ignore the fact that the sub level seems so much higher than the speakers. In order to measure the post-AccuEQ response of the height speaker I had to use the "All Channel Surround" mode and leave only one speaker connected at a time. In "stereo" mode, the bass level is pretty normal. Also, my acoustics are pretty bad right now, so it makes for some pretty nasty dips and peaks in my room's response. It's not the fault of the speakers or receiver, this has been a consistent issue with a range of different equipment and configurations. Ok, with that out of the way...
Graph 1
Blue Trace: Post AccuEQ (distance calibration and crossover selection)
Pink Trace: Manually calibrated distance, 80Hz crossover, and external EQ applied to sub channel
I matched the levels for comparison. As you can clearly see, AccuEQ did nothing to correct the rough looking response of the main channel. This will certainly be a disappointment for many who like the convenience of automatic EQ on the front channels of the LFE/sub channel. You can also see the gain between 80Hz and 150Hz resulting from the higher sub crossover point selected by AccuEQ. Not much else to say there other than I find the bass to be a bit boomy with the higher sub crossover setting and no EQ on the sub channel.
Graph 2
Green Trace: Before AccuEQ
Blue Trace: After AccueEQ
Above the sub crossover point it looks like AccuEQ actually did a very nice job of evening out the broad peaks and dips in the response of the front height channel. It appears to have attempted to flatten the response, rather than match it to the response of the mains. I'm not sure if that's a good or bad thing in this case, with the mains being as bad as they are, but at least there is a measurable improvement where it was needed. Again, no evidence here of any EQ being applied to the LFE/sub channel.
Graph 3
Based on what I measured and heard, I'd love to see what AccuEQ could do with the main channels and some EQ to the LFE/sub channel.
One other major concern I have not yet mentioned is the fact that AccuEQ only takes measurements from one location. Competing room correction programs will often allow the user to place the mic at several different seating locations so that adjustments can be made to provide a uniform experience for all listeners. Although I am usually the only listener in my HT, I still think the ability to measure the system from multiple locations within the room is a critical feature.
Overall I would say AccuEQ is definitely a solid improvement to the out-of-the-box performance of the NR737. The whole system blended well after auto calibration and response was as good as could be expected, considering my room's acoustic challenges. Lack of EQ on the main and sub channels will likely be a show-stopper for those who prefer more advanced room correction. I personally like the flexibility of an external EQ for the sub, so I was not too bothered by that missing element. There is some great potential here but also some room for improvement in the form of additional features.
General Impressions
Based on my experience with Onkyo's TX-NR626 last year, I was expecting to be pleased with the performance of the next model up the chain. Overall the NR737 performs very well. It is very easy to set up and operate, it has most of the features I would want or need, it has lots of power, sounds great, and has been completely problem-free. It even shut-down to protect itself when it detected a short in a damaged external sub amp. It is responsive and easy to navigate once you learn the menu structure. Firmware updates over the network were quick and easy. The Spotify streaming app worked well for me, though it was a bit sluggish at times. I don't believe it was a network issue, as the actual music/streaming quality was always very good. The availability of different Dobly, DTS, and THX surround modes was nice, though I found myself favoring Dolby PLIIz once I had everything set up and calibrated. It integrated well with my system and never gave me any HDMI connection/switching issues. It has enough settings options to provide users with lots of flexibility, but not so many that it is overwhelming. You tell it what you want, and it just keeps doing that until you tell it something else. On-screen menus are well organized and should be intuitive for most users.
The NR737 provided a great audio experience with a range of different speakers, from traditional, lower-efficiency models to high-efficiency speakers like the Chane Theater Tens. Either way, it could drive my whole system to levels that created an exciting and enveloping cinema experience. Rarely, if ever, did I find myself wishing it had a more powerful amp section. Musical instruments and vocals sounded clean and clear, with good imaging and soundstage. Movie dialog and sound effects were also clear, with good separation between elements and plenty of power to fill the room.
Music Performance
Dave Matthews & Tim Reynolds (Live At Radio City, Blu-ray)
I tried stereo and surround modes with this Blu-ray and both sounded excellent. Start it up, turn the lights down a bit and it's easy to just relax and listen all the way through this concert. I got the feeling of being inside the Radio City Music Hall, surrounded by hundreds of other fans. Much less smokey than a typical Dave concert, but I wasn't missing that part of the experience. The vocals and acoustic guitars complimented each other very well. Even though there were only two instruments on stage, a rich sound filled the room. Clarity was excellent and nothing seemed out of balance.
Movie Performance
Jack Reacher (Blu-Ray)
The Chevelle chase scene has become one of my go-to surround test movie scenes. First, the sound of that V8 is front and center throughout the action. There's just something about the roar of a big ol' American V8. The chase brings Reacher from an open road, through a tunnel, across a bridge, and through the alleys of a city, littered with construction equipment and cones. Not only do you hear the power of the V8, the screeching of the tires, but you feel surrounded by the difference environments as the chase progresses. The audio for the whole sequence is well-engineered in my opinion, and the Onkyo presents it in a very exciting way.
The Dark Knight Rises (Blu-Ray)
Another chase scene - Bane and his army have just easily escaped the stock exchange with hostages and begin to lead Gotham's police force on a hunt for himself and, eventually, Batman. The usual mix of car and motobike sounds, along with gunfire, crashes, and dialog all come through clearly and pretty well balanced. The Hans Zimmer soundtrack drives the intensity to the next level and adds to the complexity of the audio sequence. Each element came through with good clarity, allowing me to focus on the characters and the plot as the story develops. Then the music and action stop, and "The Bat" makes an appearance. The bass rumbles with an insane amount of intensity, and stunned police officers are blasted with the gnarly whirl of The Bat's propellers as it glides away. I was able to crank the volume pretty high during scenes like this without any perceived loss of quality.
Overall Value
In my opinion, the value of a receiver is pretty heavily dependent on features. Most modern network receivers will cover all of the bases like multiple HDMI inputs and outputs, multiple zone audio, network firmware updates, bluetooth audio connection, 4k video capabilities, built-in internet radio and audio streaming services, automated room correction, 7-channel amplification that can be configured for different speaker and surround setups, THX certification, the list goes on. The Onkyo TX-NR737 has all of these and many more. But there are two features new to the Onkyo lineup this year that I suspect will be deciding factors for many potential buyer. Those two features are AccuEQ and Dolby Atmos. Many are considering AccuEQ as a major downgrade from the Audyssey systems it replaces. It is definitely basic in comparison to MultEQ XT/XT32 and some will consider it to be insufficient. BUT... the NR737 also happens to be the least expensive Onkyo model that is Dobly Atmos equipped (as of this month). This is a pretty major update, and potentially a game-changer for many consumers. Although the loss of MultEQ may seem like a huge sacrifice to some, the fact that an Atmos-equipped AVR can be had for well under a grand is nothing to ignore. Here's the way I see it: if you're obsessed with having convenience of Audyssey's room correction, look elsewhere. If you like the idea of pretty basic automated setup/calibration, but REALLY like the idea of adding a set of overhead speakers to your system to experience Atmos, this Onkyo is a solid choice.
Conclusions and Recommendations
While the majority of the performance and features of the NR737 remain relatively the same compared to Onkyo's 2013 models, there are some major changes that also make it pretty unique. So, what do I think? Well, here is what I liked: easy setup and operation, great reliability, good balance of looks and functionality, good sound quality, Atmos capability. Here is what I didn't like so much: occasionally sluggish response in the Spotify app and the fact that AccuEQ doesn't EQ the front and LFE channels, and only allows measurements taken from one seat. For anyone looking to do a smaller Atmos installation I would definitely recommend the NR737. It's a good value and a good performer with more than enough features for the average person. I have definitely enjoyed my time with it.
Review Discussion Thread
More About This Product
Specifications
Product Site
Onkyo.com
MSRP
$899 ($999 from ShopOnkyo.com, $795 from Amazon.com)
Overview
THX® Theater-Reference Sound Meets Ultra HD Entertainment
Step up to THX-certified surround sound with the TX-NR737—the most potent and future-ready A/V receiver in its class. With a high— current massive transformer, discrete Three-Stage Inverted Darlington Circuitry amplification, and extremely robust construction, this heavyweight serves up floorshaking theater-reference sound. There are 4K/60 Hz-capable HDMI® 2.0 inputs for Ultra HD gaming and video at 60 fps, as well as support for HDCP 2.2. As most Hollywood movie studios are adopting HDCP 2.2 copy protection for future Full HD and 4K releases (including content streamed via the internet), this is a highly desirable feature. Also included is Qdeo™ 4K upscaling technology so you can enjoy older DVDs and games in high resolution. Music lovers can choose from a selection of internet music services and stream almost any 192/24 hi-res, lossless, or compressed file format (including 5.6 MHz DSD) from compatible network- attached devices using built-in Wi-Fi® and our free remote app. Bluetooth is also built-in. Combining these features with class-leading sound quality and an easy-to-use GUI, the TX-NR737 delivers powerful studio-master entertainment at an affordable price.
Feel Every Dimension in Dolby Atmos™
Enter a new world of sound with Dolby Atmos®. It transports you from an ordinary moment into an extraordinary experience with captivating, multidimensional sound that fills your room with amazing richness and depth. Music, people, and objects come alive in breathtaking detail and flow in precise choreography all around you, making you feel like you are truly there.
This Onkyo receiver features Dual 32-bit DSP engines to decode and scale Dolby Atmos to your home theater layout. With 7 channels of high-current amplification, you can unlock the full experience with in-ceiling height channels or Dolby Atmos-enabled speakers to augment a standard surround sound home theater setup for stunningly detailed sound that comes alive from all directions, including overhead.
Welcome to a new world of sound that delivers the full impact of entertainment. It will move your mind, body, and soul.
Specifications
More About This Review
Features
Reviewer
Peter Loeser (Archive)
Peter’s Home Theater
The evaluation of this equipment was conducted in a 14"3" x 16'10" (2300ft³) sealed home theater with seating for seven. First reflection points on the side walls have been treated with GIK Acoustics 244 panels. Speaker locations are fixed within the parameters of the THX/Dolby/DTS/Audyssey recommendations for up to 11.1 channel surround sound. Subwoofer placement is determined by ear and REW measurements for best response before any EQ or room correction is applied. All measurements are taken with Room EQ Wizard and a MiniDSP UMIK-1 (calibrated by MiniDSP). In most cases, the majority of the review is done from the main listening position, however subjective evaluation may also be done from multiple locations to test uniform system response throughout the seating area.
Audio Equipment
Receiver: Onkyo TX-NR737
Mains & Center: Chane Theater Ten
Surrounds: Definitive Technology Studiomonitor 350
Subwoofer: Chane Power Package Two
Video and Source Equipment
Display: LG PV250 60" Plasma TV
Blu-ray Player: OPPO BDP-103
Media Streaming: Apple TV
Media Server: Mac Mini Server
Cabling
HDMI: Monoprice/Rosewill with Redmere
Speaker: Monoprice 12ga CL2 in-wall
Sub/Interconnect: Monoprice CL2 RG6 Coax
HTS Reviewer
Discussion Starter #2
Onkyo TX-NR737 7.2-Ch Network A/V Receiver Review Discussion Thread [Draft]
Introduction
There has been a lot of news this year related to AV receivers - major new technologies, questionable changes in room-correction features, and big brand partnerships. Onkyo seems to be right in the middle of all of it. The company began releasing updated models to it's TX-NR line of networking surround sound receivers. Confirmation of Dolby Atmos capability and the loss of Audyssey immediately sparked debate and speculation throughout the home theater enthusiast community. While some find the thought of an Atmos capable home theater thrilling, others consider the absence of Audyssey a complete deal-breaker. If you like the idea of pretty basic automated setup/calibration, but REALLY like the idea of adding a set of overhead speakers to your system to experience Atmos, check out the full review!
HTS Reviewer
Discussion Starter #5
Almost done. I remembered today that Onkyo likes to fact check the reviews. I don't mind it as they have been able to clear up some questions for me through this process in the past. I'm going to submit a draft to them today and finish up the "Music" section as well. I'd like to have it published mid week.
Todd - I see you have an announcement ready. I'm happy to wait until it's had some time on the front page. I'll let you know when I'm 100% ready to post this one.
LOL.
Well, I took a chance and tried to slip one in there. You can publish over it whenever you are ready. The last SVS story I wrote has gotten over 9,000 views...so I wanted to get their new speaker announcement out there. Since you hadn't gone up yet today, I decided to sneak it in.
No worries tho. Take your time!
1 - 7 of 7 Posts
