1 - 3 of 3 Posts
My question: Is the output level for a subwoofer, on the onkyo txsr605, high enough to push the ep2500 to full capacity? Cause I know the ep2500 has a different input sensitivity. Do I need a cleanbox/eq?
Powering a mael-x incase you were wondering. Curious cause onkyo website says 200 mV/470 ohms (Rec out)
I was wondering if anyone had actual experience connecting these things up...
Thanks for your input!
Erik
Hi there,
My onkyo 876 runs my Behringer EP4000 with no problems at all. Ive had the volume on my behringer on -4db on the onkyo running my dual sealed sub.
cheers
Graham
My 805 also runs the EP2500 fine. I easily get reference levels without any extra boost. I don't have the manual handy as I'm at work, but it should be easy to compare the output voltage of my receiver and GPs receiver to yours.
The only issue I ever had, was ground loop...
1 - 3 of 3 Posts
