And also may be you guys have an idea regarding with my PS3 and 807. My 807 cannot recognize the PS3. What I can see in 807 is a blinking HDMI icon from the display panel. thanks
All right. Regarding your first original issue, and now that one, try this:
1. Under the flap door of your 807, there is a button called 'HDMI OUT', press that button until you get a picture on your screen. It should be set to 'YES', as when your TV display is connected to the HDMI OUT of your 807.
2. Also, the HDMI Audio should be set to 'OFF'. Look in the Advanced Setup in your 807's manual, near the end.
3. Also, in the Advanced Setup, you should Disable 1. Lip Sync 2. xvYCC 3. Control 4. Power Control 5. TV Control.
4. Also, you should set the Immediate Display to 'OFF'. Again, from the Advanced Setup.
5. Finally, from your PS3 audio setup menu, enable all type of audio resolution, including multichannel LPCM.
And from the video setup menu, choose the appropriate video setting.
6. Last and not least, as previously mentioned, make sure that all your HDMI cables are fully inserted into their jacks and perfectly sound.
* And don't forget to let us know how you're managing.
Cheers,
Bob
