1 - 4 of 4 Posts
hy
i am new user of REW.
i have a problem with using SPL meter.when i use logger and record the data.i cannot open it in REW.i attemped with all of the supported types such as txt. but everytime i recieved this error.(i attached it to mail)
i wanna obtain frequency response of this data.what should i do?
You cannot generate frequency response data from sound pressure readings, the sound pressure values are generated by summing the contributions of a series of data samples over an integration period, the original data is no longer available. It would be like looking at the figure on the display of your SPL meter, there's no way to take that figure and determine what frequencies contributed to it.
1 - 4 of 4 Posts
