1 - 20 of 48 Posts
I had this idea for a bookshelf without a specific driver in mind. It would be something like an anarchy 5.25" or 6.5" midwoofer with either one or two midrange speakers side by side up top along with maybe a ribbon tweeter above them in a sealed box. The jack would be at the back and will have the wire glued in the corner going up the port, along the top to a crossover embedded in the little wall and then down to the woofer/midwoofer. Inside the smaller box would be another crossover for the mids and tweeters. Hoping to get it done with a 5.25" and have a decent bass range with minimal space taken up. That way I can put 100+ watts into it and have an excellent sound all around. I have a rough draft made up in paint.
Looks like a nice design, have you had your hands wet in DIY speakers before? In about 2 weeks as long as the weather keeps getting nicer i'm going to take my first real leap so i will certainley be curious of your turn out.:T
This is a slot-ported box. It'll work well, just model the result before building using T/S parameters in something like Unibox of WinISD simulators. This long a port is rarely required by anything but a subwoofer. The mid-tweet box is good practice.
My real question is why you'd make such a small 3-way; there are a bunch of very nice MT designs this size out there....
Looks like a decent design but picking drivers that will work nicely together is the trick. Then building a adequate crossover to finish it all off but don't get me wrong it is much more complicated than it sounds.
Hey bambino what drivers did you end up choosing. I remember you had a thread about building towers. I'm almost done Doing the finishing on mine.
HIGHJACK!: I ended up with Peerles HDS 6.5" bass drivers, Peerless HDS 5.25" mids and Vifa t25 1" tweets. Still waiting for a bit warmer weather before i start things off. I look forward to seeing your finished results.:T
What are MT designs? I want to go with small foot print with a decent bass response. If the port is too long, I can shorten it and do some more to increase the internal space before the port starts and get about 1/2" of polyfilll lining the inside if needed. Now why would I have to worry so much about matching speakers if it's going to be a straight up cutoff with the crossovers?
I can remember some decent sounding bookshelf speakers from 25 years ago by a company called Design Acoustics that utilized a downfiring woofer.
Well if I was going to do that, I would get one that would fit under the midwoofer, keep the port the same except have it vent out the back. When I thought about one that would fit, a downfiring woofer in a bookshelf just seemed like an awful idea as far as sound direction goes considering these would hopefully drop off at about 50hz given the size (if I'm lucky).
I'm going to have to wait to open that link. The reason I'd want two mids is power handling. I know the midwoofers take most of the heat in regards to power consumption. I see other builds involving multiple 4.5" full range speakers. That is what I was thinking of using in regards to having two mids. If need be, I would seal them off from eachother. I was going to use the 16 ohm driver seen here.
Now that's a nice looking midwoofer... 6mm xmax on that little guy! Does that mean you'd be crossing real low on the bottom half for those, like ~100Hz, or are you thinking MT/TMM/MTM now?
Discussion Starter · #14 ·
Unfortunately good sir, I do not know what those terms mean. The thought of having a crossover that low has occured to me, maybe a little bit higher around 120-150hz. What I wouldn't mind is finding a 4 or 16 ohm version of this tweeter to have a diagonal layout where it's a tweeter in the top left and mid right and a full range driver in top right and mid left if that makes any sense.
That's what I was wondering, hopefully you have active Xovers planned. Otherwise the component values will be HUGE for a passive Xover that low. At any rate, two of those isn't a bad idea to keep sensitivity up... which will also be a concern for whatever woofer you have in mind.
What do you mean by component values? I WAS going to go for a passive (and probably still will) as I want to have everything except an amp tucked away in the box. Also, what does MT/TMM/MTM mean?
Component values, as in uF and mH for coils and caps. Higher values get expensive quick.
MT, etc. are different arrangements for mids and tweeter.
Discussion Starter · #19 ·
Thanks for the explanations. I think I'll try for a x-over around 150-200 for cost efficiency. I'm going on referance to the Anarchy 6.5" midwoofer with an Spl of 84.7 dB/1W/1M. Then with two of those full range speakers with an spl of 85.8 dB @ 1W, 1m. I tried to find an appropriate tweeter close to 4 ohms but the ones I did find had an SPL in the 90's. I found one with an spl of 89 dB 1W/1m that says 8 ohms but says Re: 5.5 ohms. I'm thinking I'll wire it up to 11 ohms and that will drag it down a bit volume wise. Is my thinking in this matter correct?
I used a pair of off of the shelf xovers in a set of 3 way party speakers from PE and they are working out great. They only ran me like 45 bucks for 2 of them. They also had link-reily xovers from Dayton for not too much money.
1 - 20 of 48 Posts
