1 - 7 of 7 Posts
I have an idea if i use oppo 95 as a pre and look for power 5 ch, is that possible ?
It's only practical if the Oppo comes with a volume control separate from the level controls. I have a DVD player that can do that but it's a rare feature.
Thanks Ovation123, yes i also concern about the level because increase volume step 5, may be i have to change my idea.
Cheers
It is possible however you would have to use the 5 channel amps level controls (if it has any) and would mean that you would have to get up each time you wanted to adjust the volume. You would also have no EQ or any other processing.
Re: oppo 95 - volume for analog only
It does have volume controls on the remote, but is only applicable to the analog outputs:
From the manual, p.31:
"On the BDP-95, the volume control only affects the analog audio output.
It does NOT apply to digital audio output (HDMI, Coaxial and Optical) either
in raw bitstream format or in LPCM format.
Cheers,
XEagleDriver
Discussion Starter #7
Thank you all i will try soon
P.S. Could you guys advise me for which one power amp, I'm interested emotiva.
1 - 7 of 7 Posts
