As far as I am aware although not using them (HDMI only) you do need to apply a 10db boost for the analogue outputs.
As far as I am aware although not using them (HDMI only) you do need to apply a 10db boost for the analogue outputs.Does the BDP-83 add the +10dB to the LFE on the analog outputs,if I were using it to do the decoding internally and then out of the analog outputs to my processors 7.1 analog input?
