1 - 3 of 3 Posts
HEy guys, I'm in trouble and need a bit of assistance :(
just bought divergent and the amazing spiderman 2. neither of those movies will load. it loads the rest of my blurays without problems.
divergent is a 2 disc with special features on second disc. movie disc fails on loading display says unknown disc.
special features disc load and runs just fine.
amazing spiderman 2 is also not loading and says unknown disc.
i have tryed updating firmware, i have tried resetting player and doing new setup, both disc are new out of the plastic, and with no spots or dirt on them.
any good ideers?
panduro
Are you sure the region is correct on the two BluRay discs ?
HEY Tony and thanks for ur reply…
its a good suggestion, have made that mistake before :)
i can't really be sure sure, i cannot find a region code on either of the discs, on the cover the writing us in the right language for my code is used so i think its the right region code. how can i make sure?
best regards
panduro
1 - 3 of 3 Posts
