Status
Not open for further replies.
1 - 2 of 2 Posts
I am selling a slightly used Oppo DV-981HD
I have original packaging and paperwork
Price: $150 shipped in the CONUS
Here are the Features:
Universal DVD Player Features:
DVD-Audio, Super Audio CD (SACD) and DVD-Video universal playback
Compatible with Audio CD, HDCD, WMA, Kodak Picture CD, and other digital audio/video/picture media and formats* (*Note: The DV-981HD does not play Blu-Ray nor HD-DVD discs)
Official DivX® Certified product, certified to the Home Theater Profile
Plays all versions of DivX® video (including DivX® 6) with standard playback of DivX® media files
Plays XviD and .SRT, .SMI, .IDX and .SUB format
Compatible with CD-R/RW, DVD±R/RW and DVD+R DL* (*Note: Compatibility with user-encoded contents or user-created discs is on a best effort basis with no guarantee due to the variation of media, software and techniques used. For example, Discs recorded on some stand-alone DVD recorders or DVD camcorders may not exhibit smooth playback. )
Video Up-Conversion Features:
High definition up-conversion with film-like picture quality to up-convert 720x480 interlaced video encoded on DVD discs to 480p/720p/1080i and 1080p
DCDi by Faroudja video processing technology with progressive scan, film mode detection, TrueLife™ enhancement and motion adaptive noise reduction.
Video is analyzed on a single pixel granularity to detect presence or absence of angled lines and edges, which are then processed to produce a smooth natural looking image without visible artifacts (jaggies)
High-quality pure digital video and audio through a single HDMI (High Definition Multimedia Interface) cable
Multiple high definition video formats through HDMI output: NTSC: 480p/720p/1080i/1080p; PAL: 576p/720p/1080i/1080p
Compatible with HDTV, HD-Ready TV, HDTV monitors and projectors with an HDMI or DVI input
Direct PAL/NTSC disc and TV compatibility and system conversion
Supports screen aspect ratio 4:3 (standard) and 16:9 (wide-screen)
User adjustable video controls: Sharpness, Contrast, Brightness, and Saturation
Composite video and S-Video outputs (standard-definition output only)
Optimized Audio Features:
High-resolution multi-channel digital audio output through HDMI supporting CD, DVD-Audio, SACD, Dolby Digital and DTS sound tracks.
Individual analog 5.1-channel surround and down-mixed stereo outputs
24-bit, 192kHz high resolution audio D/A converters
Optical and coaxial digital audio outputs with DTS, Dolby Digital, Dolby Pro-Logic II and Linear PCM support
3D Surround (Virtual Surround): Concert, Live, Dance, Techno, Classic, Soft
Built-in equalizer, channel trim and channel delay functions
Compatibility Features:
PAL/NTSC disc and TV compatible with automatic or manual system conversion
Dual-laser optical pickup head with excellent error correction
Enhanced dual-layer disc support with fast layer change
Wide range universal power supply (~100V-240V, 50/60Hz AC)
Convenience Features:
Special disc tray - thin, flexible and strong. Can tolerate some bending without breaking.
Smooth and easy navigation of photo albums, music collections and video files on DVD and CD
Selectable subtitle and audio tracks
Discrete ON/OFF remote control IR code for programmable universal remote controls
Connectors:
HDMI - High Definition Multimedia Interface: 1
Analog Stereo Audio (Mixed 2-Channel Left/Right): 1 group (2 connectors)
Analog 5.1 Channel Audio: 1 group (6 connectors)
S/PDIF (IEC-958) Coaxial Digital Audio: 1
S/PDIF (IEC-958) Optical Digital Audio: 1
Composite Video: 1
S-Video: 1
Thanks for looking
RayJr
1 - 2 of 2 Posts
Status
