Hello, I was wondering if anyone has any advice regarding setting up a pair of speakers to increase the width of the 'sweet spot'. I have two 'triple cushion' wide couches side by side and am looking to make the sweet spot as large as possible... I currently have each speaker setup to be angled so that the on axis response has an equal angle between the outer corners of the couches. If you look on the Picasa web the image is actually 1600x1024 instead of the 800x512 preview here...
http://picasaweb.google.com/lh/photo/Py7HOtAjLLGB7l5dLArypg?feat=directlink
If anyone has any suggestions or ideas how they would setup the speakers (the placement is as wide as I can go, the left speaker is next to a fireplace...) as far as ways of doing the "toe in" I am all ears
Thanks for your help
To describe the layout... the angled rectangles are the couches... the right wall is windows, the 'top' is a stone wall, the protrusion "down" is the fireplace, the circle in the corner is a sub-woofer, the odd shaped object near the sub-woofer is the tv stand and the points near the tv stands that make triangles towards the couches are the center's of the speakers.
Also, the circle between the couches is a 'head shaped circle' to center things around
