I've joined the cord cutting movement and started to look for a OTA receiver.
The IP's overcharge and promote 1000/1000mbs plans when not needed. E.g. just signed up for 200/200 plan which works just as good as the expensive plan and saving about $100 per month.
Next, I setout to find a good quality OTA Tuner, but all I could find were the less than $40 models. I did buy/install one with the best Amazon reviews, and it does work, but the image/sound are about 80% where I think it should be. I say that because I had a VOOM box installed and the picture (720p) was very nice, but there were other problems with memory, signal strength, etc.
I've looked for a while now, it doesn't add up that our 4k TV can pick up 75 channels (OTA) with excellent picture quality [point being the broadcast system works] but there are no mid-range OTA Tuner/Receivers on the market.
Any advice on a antenna STB 720P/1080i for a ceiling mounted projector?
Thanks!
Thanks!
