Optoma Technology
www.optomausa.com
715 Sycamore Drive
Milpitas, CA 95035
408-383-3700
408-383-3702 fax
Tech support:
http://www.optomausa.com/techsupport.asp
Service and parts are provided through a related company, Technical Service Corporation.
Technical Service Corp.
725 Sycamore Drive
Milpitas CA 95035
408-383-3700
408-383-3711 fax
888-942-2929
Optoma provides no service manuals, traning manuals, nor schematics for their products. They will sell parts at the board level only in some cases, but not for all products.
Service, technical support, and parts are provided through a related company,
Note: Lamps for the RD50 series of DLP RPTVs are the same Osram part as used in some of the early Mitsubishi sets and can be purchased for lower prices there. Be sure to cross reference the actual numbers on the lamps and be prepared to swap housings. It is very critical when doing so to only use the exact lamp and to be very clean when handling them. Any oils on the lamp itself will cause uneven heating and potential damage.
B&H photo also sells the Optoma part and has been known to have it at lower prices with better inventory at times.
www.optomausa.com
715 Sycamore Drive
Milpitas, CA 95035
408-383-3700
408-383-3702 fax
Tech support:
725 Sycamore Drive
Milpitas CA 95035
408-383-3700
408-383-3711 fax
888-942-2929
