Anyone here ever done a replacement of the drivers in the HSU 10" original sub? What would be a good replacement for their driver that would perform as well or better in terms of overall extension, output and power handling? Or would I be better off buying a direct replacement from HSU?
Hotshoetom
Hi Mike,
thanks for the link but that is a fully assembled unit. I looked on Dayton's website for a replacement driver for that sub, but found no listing. I did however run across one that looked promising. I havent run it through the enclosure program yet to see how well it would match up to the existing tubes, but I will get that done here in a day or two. The one I was looking at is here:
http://www.parts-express.com/pe/pshowdetl.cfm?&DID=7&Partnumber=295-460&ctab=2#Tabs
Seems like that would be a good match for those small enclosures... any thoughts?
Tom
Yes, I was thinking P.E. would have a replacement driver for it if it's a clone of the HSU. As for the link to the Dayton sub to see if it works, what is the internal volume and tuning of the HSU sub?
