1 - 4 of 4 Posts
I am looking for an outboard unit just to apply SS filter to my 2 subs to keep the ultralow stuff out & prevent overexcursion. I am looking for something that has two sub inputs and two outputs & that doesn't alter the signal in any way other than applying the SS filter at 10 or 15Hz. I am planning to EQ the subs using Audyssey MlutiEQXT32 with Sub EQHT which sets the distances/levels separately for 2 subs & them EQ's them together. I am looking for a unit that does not interfere with functionality of Audyssey EQ. I am wondering if Reckhorn B1 or B2 will do the job.
Thanks.
What type of filtering / crossovers are built into the subs? Depending upon the sub the lower end may be covered. I am not certain of specifics but some amps have protection for lower end also.
DSpeaker from CSS that will get you exacctly where you want to go. and it will do it with the least amount of problems.
Mark
I have the B1 and I think 15Hz is pushin' it. I have not measured the response of mine but there was another review posted here somewhere and I think that unit's lowest filter was 18Hz.
Bottom line was that the cutoff frequency was not exactly super accurate.
The B1 will do the job if you're not super critical.
1 - 4 of 4 Posts
