I have been surfing around the DIY Screen board for the last couple of weeks. The amount of information I have found is just overwhelming. I really enjoy reading about all the testing people have done on the various types of screens. There seems to be a lot more going on here than another forum that I started out on. I have made my way through most of the threads in the sticky section. What a valuable resource those threads are for someone, like me, just starting out in the projector world.
I will start off with my setup. Epson HC 6100, recently picked up on clearance. I, like most, I have gone against the advice of the board and purchased the PJ before thinking about the screen. That's what happens when you purchase a PJ and then realize you have no idea on what to do about a screen. Next time I'll know better. At least I feel that this unit is a decent choice for my viewing needs. The PJ is ceiling mounted 11' 6" from the screen, ceiling is white and walls are a light tan color. See pics below.
Projector
Screen wall
The PJ is located in my basement (approx 25' X 25'), which also is the kid's play run (they are no longer allowed to throw anything), wife's office area (I built her a cubical), and gathering place for the guys to watch sports and play cards. There are two windows that can be blocked off with BOC to make the basement completely dark during the day. Three zones of reset lights are all on dimmer switches.
Viewing: Sports with low light levels in the area furthest away from the screen and movies in complete darkness.
I started off by projecting the image on the tan walls and everyone thought the picture still looked great. A couple weekends ago I marked off the area of the screen, which by the way is a 98" diagonal (almost forgot that key point), by projecting a blue image on the wall and used a level to outline the screen area in pencil. Then taped it off with blue painters tape (about one inch outside the pencil line) sanded the wall with a finish sander, and painted the area with Kilz2 (as recommended). I calibrated using the THX setup, at least the best I could without having the blue filter glasses. I'll do a better calibration once the screen in completed.
Getting ready to paint.
In this picture you can see the tape is outside the line that defines the screen area.
Painted with two coats of Kilz2.
My thoughts of the Kilz2. The image is definitely more enjoyable, in my eyes, than it was on the tan walls. The black levels look great in a completely dark room but could use some help with a little ambient light. The image is both sharper and the contrast seems better. I'm sure some of the improvement could be from my calibration attempt, allow I did not have to adjust the settings that much from the factor settings.
I would like to move onto one of the gray mixes. From what I'm reading this should help some with the light reflection and ambient light while watching sports with friends. With my setup and room would you recommend going with an N9 like the C&S or going darker (N8.5 or N8)? I am also willing to give any developmental mixes a try if needed. I would just need someone to guide me through the process.
Hi John, thanks for the very informative first post. :T
This is where things get subjective and the shade of gray you go with depends on which you like better - bright whites or dark blacks. Personally, after reading the review of your PJ at projectorcentral I would go with a Black Widow™ screen in your situation (I love my black blacks). If you don't think you would like something quite this dark I would then recommend Scorpion™ N8 for a tried and true mix, or if you're feeling a bit daring, try the semi-experimental Elektra™ N8 mix (two people have made full size screens with this mix and really like it).
Thanks Don. I am little concerned going with a shade as dark as the Black Widow. Do you think there would be any problems going that dark as the bulb ages and looses some of it brightness? I am currently running the PJ on the Theater setting. Not sure if that matters. I am really considering trying the Elektra N8. Have you been able to do any comparisons between Scorpion N8 and Elektra N8? I plan on rolling the screen. Does one roll better than the other?
Just realized I made a mistake. Went to Joanne Fabrics this past weekend to purchase BOC for the windows. Since I was already there I decided to get the fabric for the screen surround. Ended up purchasing Black Felt instead of Black Velvet.:whistling: I thought the cost per yard seemed low compared to what I was reading. Well back to the store. Hoping the wife has one of the 50% off coupons.
Yeah, running in the lower light modes would affect your screen choice. If I've run the numbers right, your PJ in Theater mode (and I assume low lamp mode as well), and at about 1/4 zoom, gives you about 360 lumens of light which for your 98" screen works out to 12.5 fL. which is less than half of what the projectorcentral calc gives for your PJ. The good news is that the PJC calc already allows for a 25% decrease in lamp efficiency due to lamp aging so at worst you could take another 25% off for maximum lumen drop-off due to lamp usage. This still gives you about 9.5 fL. as a worst-case scenario. With this in mind, Scorpion™ N8 or Elektra™ N8 could be the better choice.
We are still some time away from side-by-side testing of these mixes. I'm guessing they will work about the same, but Mech thinks that Scorpion™ would have the brighter whites. We won't know until the actual testing. Both mixes roll well with no preference between them.
Apologies for my ignorance, but how did you come up with 12.5 fL? Are you using the projector central calculator for the EP 6100? If so, how did you change specific inputs (lumens, zoom, etc)?
No apologizes necessary. I used the data from the PJC review of your PJ (here).
In Theater mode they measured an actual 526 lumens. Low-lamp mode dropped brightness 24% which left 400 lumens. Zoom at full telephoto dropped brightness another 41%, 50% zoom was 20%. I noticed that in your case you were using about 1/4 zoom which I interpolated to be about a 10% brightness drop. 10% of 400 is 40, 400 minus 40 leaves 360 lumens. At a 16:9 ratio your 98" screen would be 48hx85w inches, multiplied together gives 4080 square inches of surface; dividing that by 144 gives 28.3333 square feet. Dividing 360 lumens by 28.333 gives 12.706 foot lamberts (or lumens per square foot).
While I can't get it to do it now, I think the first time I used it the PJC calc. was telling me a 98" screen was 49x85 which lead to the 12.5 fL. figure when I rounded it. No matter, I guarantee you will not notice a 0.2 fL. difference in screen brightness.
I'll take another read through the Elektra and Scorpion N8 threads. Any specific questions about these mixes will be post in those threads.
I just had to yell this news out....Black screen paint....some guy has this on youtube.
I for one can not wait to try it.I have tried getting deeper blacks and descent ambient light
screens.He should have a website up soon.:yikes:
Extreme newbie question here. Will there be any long term bad effects if I paint primer on my wall to use as a screen and then repaint it later when I learn enough and acquire a good paint/paint mix for the actual screen? I'm thinking of rolling it on. 1/4" nap seems to be a recommended...
I have an unfinished basement, an average projector and want to make a screen to hang over the white plastic insulation walls. I'm also surrounding this home theater area with painters drop cloths and buying blackout fabric for the window. My question is.... what do I make my screen out of? It...
Hi. I have an Epson 2030 that I would love to bring outside for movie nights. I have been looking at this screen material and am wondering what would be the best way to build a frame that is durable and cheap at the same time. Anyone ever done this and have instructions and pictures? I also want...
Can I use a 7.5-in x 48-in Stair Riser that I had left over as a french cleat to hang my 53" X 93" 1x4 flat frame Poplar projector screen? The width of the riser is not quite 3/4". It is a 1/16" shy of 3/4". Thanks.
