1 - 8 of 8 Posts
I am building a 4 ft3 enclosure out of mdx and want ideas in a nice looking finish. I thought about paint, but not sure it would look cheap. Rhino liner crossed my mind. I even thought about the rough wall texture. What are some ideas please?
Thank you
Senior Shackster , Platinum Supporter
the laminate is interesting but is it difficult to get on there evenly?
It's actually very easy. Use a water based contact cement and cut all pieces slightly bigger so you have a 1/4 inch overhang. Each piece is glued on and trimmed with a router and trim bit so the laminate is flush with the cabinet. One $65.00 sheet of laminate will cover a 8 cubic foot box, depending on the dimensions.
What about using granite on top and use it as table ...
To get more ideas ... Where are you planning to place it??? (corner, rear of sofa, hidden, etc.) :huh:
1 - 8 of 8 Posts
