FYI. I'm looking at Kilz premium primer.
Sorry to revive this, DqMcClain, but as I have a similar question I'd like to know - which paint to use? As I've checked an article from projectorcentral, it seems that they've banned Sherman Williams. And there was no updates since 2018. Now I'm looking for other budget friendly options and stuck upon SmarterSurfarces. Have somebody tried it? Couldn't find any feedback and has been wondering, whether this or any other options from their list are working.Texturing will definitely affect picture quality... the smoother the surface, the better. Blurring is more likely either a processing issue, or an optical issue with the projector itself, but something like the orange-peel texture of a residential interior wall will create tiny shadows where there aren't supposed to be any (especially at the edges of the screen) and will also reflect light back at silly angles instead of where it's supposed to go. The net effect is a degraded image.
Check out this article from Projector Central: http://www.projectorcentral.com/paint_perfect_screen_$100.htm
The short version is you can buy an un-tinted base white paint and get a perfectly acceptable screen. It also describes a reliable procedure for painting the wall so you get good results, not just from the paint itself, but so that you end up with nice clean lines and surfaces.
This may be a bit more labor intensive, but installing actual sheetrock in the size of your screen would be the best way to achieve the best long term results.Extreme newbie question here. Will there be any long term bad effects if I paint primer on my wall to use as a screen and then repaint it later when I learn enough and acquire a good paint/paint mix for the actual screen? I'm thinking of rolling it on. 1/4" nap seems to be a recommended roller. I'm not opposed to sanding and have sanded some of the texture off to find the wall is some kind of fabric/knit type pattern that I guess they just painted over. I'm not sure what material the wall is other than it's not a Sheetrock unless they started covering it with cloth.
I think I would spray the final coat when I get to that point and can keep from spraying onto furniture. I have a wagner airless paint sprayer, but I've only used it to paint a barn and the finish was not demanding at all.
