1 - 20 of 24 Posts
I have a pair of subs JBL GTI 12 in the basement collecting dust. My plan is to use them to complete the home theater setup, if they are good for this purpose . Hope someone can help me on the box and the frequency tuning, I try winisd but I am new to the program, so I don't know if the info I am coming up with is correct. Also I need to decide which amp is better for a 3.2 (bridge) or/and 6.4 ohm load, my current options are a Crown XTI 2000 or a Behringer 2000 but any suggestion are welcome.
Thanks…
The parameters are already in winisd.
Qts: 0.510
Vas: 44.23 l
Fs: 31.83 Hz
Re: 3.2 ohm
Le: 0.75 mH
Xmaz: 20.3 mm
Z: 4.0 ohm
Qms: 6.680
Qes: 0.552
SPL: 86.16 db
Pe: 700 W
BL: 14.64000
Dd: 24.72 cm
Sd: 480.0 cm2
Mike, thanks for your quick reply and sorry about the model of the subs. Can you send me the winisd file? I can't get the same results as you.
Mike, I wonder if we can go with a lower tune frequency, let’s say 16 Hz, with a bigger box and vent. I want to take the advantages of an LLT configuration. My primary use is for movies. I'm not an expert on these matters so I don't know if this subs a suitable for this kind of configuration. Thanks in advance.
7 cu.ft tuned to 16 hz (each) would be as far as these can go. 600 watts input with a hi pass filter at 15 hz would protect the sub. Porting would be a 6" diameter round port 38" long to keep the port air speed under 24 m/s at 15 hz. How big is your HT room? Is it sealed from other areas or open to them?
Text Electronics Technology Line Font
Those W12GTI's are awesome subs. I've always wanted to try one myself. Hopefully that differential drive motor design doesn't get swept under the marketing rug.
I'm going to build the box tuned to 21 hz. Here is a draft, any comments or suggestions are welcome.
Thanks Mike for your help.
Cylinder Diagram Display case
This is it, I’m starting the build this weekend.
I change the frequency from 21 to 20 hz. The new specifications are as follow:
130 liters (160 liters total with port and braces)
1 rectangle vent of 26 x 7 x 93.58 cm
1st port resonance 183.63 Hz
Port Air velocity 22 m/s
Any comments or suggestions are welcome.
Technical drawing Major appliance Diagram Door
Furniture Table Parallel
I remember eyeing those JBL GTi's with envy, years back. I'm curious to see the end result.
Discussion Starter · #18 ·
Since the pictures of the other builds help me to improve my design I will post some pictures of my progress.
I will finish the vent tomorrow and starts the final assemble.
The box is huge and it weight like 150 pounds (ask my back).:yikes:
Workbench Wood Furniture Table Desk
Workbench Tool Mortiser Machine Milling
Wood Plywood Hardwood Table Wood stain
Wood Plywood Lumber
Wood Plywood Table Architecture Metal
Subwoofer Car subwoofer Loudspeaker Audio equipment Tire
Technology Audio equipment Tire Automotive tire Electronic device
Discussion Starter · #19 ·
Finally the subs are finish. I did some testing today and these things are going to blow my house.:hsd: One of the first test movies was Transformers 2 and at the beginning when the stars appear I have to jump for the remote to turn the volume down.
This week I will take some REW measurements and share it with you guys.
Wood Table Plywood Wood stain Furniture
Wood Wood stain Plywood Hardwood Circle
Wood Plywood Hardwood Furniture Table
Loudspeaker Audio equipment Sound box Computer speaker Birdhouse
Birdhouse Birdhouse Wood Pet supply Plywood
Loudspeaker Sound box Electronics Audio equipment Subwoofer
1 - 20 of 24 Posts
