1 - 3 of 3 Posts
Now that my Sony is dead, this Panny is what I have (well I do have a 20" Sony KV-20FS100 but it's a bit on the small side).
It has a pretty weak PSU (the lines are bent no matter the setting), and using Avia I cannot even set the black level, cannot see the moving bars. So the question is,.... is it worth getting into the service menu to try and get a better picture, or just live with it? Movie wise it is a pretty nice picture,...considering what it is. But TV wise (Dishnetwork) the color and darkness is a little annoying.
It is all set up using component 480i inputs,.... the picture does seem like it was a bit lighter when it was set up in the bedroom and used the coax input.
Any thoughts? While I consider new TV options and await a response from the local authorized Sony tech.
Plain ole user
I am not sure what you would do in the SM to improve it. These sets were rather limited in what you could get out of them.
1 - 3 of 3 Posts
