1 - 3 of 3 Posts
Good day Folks.
My TV recently displayed an OSD message advising AIR FILTER CLEANING...
I was able to find detailed instruction to clean filter on light engine housing, which I did with no problems..
The problem now is that OSD message still pops up every time I turn my unit on and then shuts down in 1 minute.
When I replaced my lamp it came with instruction to reset the OSD message for lamp replacement.
I assume the OSD message can be turned of by doing a series tricks with the TV remote??
If so could some one point me in the right direction or give me the code???
Thanks
danomano
Plain ole user
Perhaps there is a malfunction in the thermal sensor or there remains some airflow issue.
Well the Message only appears when the TV is turned on for the first time in the day.
After it shuts down you can turn the TV back on and the message does not come up even after many hours(all day & night).
I would think that if it were a thermal sensor and or an air flow problem the OSD message would come on every time the TV is powered back on! Would it not?
I'm quite sure this OSD message is a timed function as per the light hour meter?
So I must ask again can some one please inform me of the code to turn this OSD message off??
Thanks
1 - 3 of 3 Posts
