Paradigm Sub 2
Specifications
Design
Hexagonal cabinet with multiple high-excursion
drivers radially aligned in a Vibration-Canceling
Design Architecture, patented built-in
Ultra-Class-D™ power amplifier with Power
Factor Correction, sealed enclosure,
PBK interface
NOTE: Due to the incredibly high power and
tremendous output the SUB 2’s grilles
are non-removable
Amplifier**: High-Current,
Discrete Output
9,000 watts Dynamic Peak /
4,500 watts RMS
Amplifier Features
Auto-On / Off, Trigger On / Off, soft clipping,
electrical shorting protection, thermal protection
Bass Driver
Six 254-mm (10 in) RCR™ mineral-filled
co-polymer polypropylene cones,
FEA-optimized overmolded thermoplastic
foam-surrounds, 76-mm (3 in) ten-layer
long-excursion voice coils,
high-temperature composite Nomex®
formers, dual advanced spiders, 25.2-lb
(10.5 kg) hard ferrite magnet / motor
structure, massive center heatsink
and oversize pole piece, AVS™
die-cast heatsink chassis
Low-Frequency Extension*
7 Hz (DIN)
Subwoofer Cut-Off Frequency
Variable 35 Hz - 150 Hz; Bypass Option
Sub / Sat Phase Alignment
Variable 0° - 180°
Line-Level Input
RCA (S/E) Left and Right or Sub-Out / LFE or
Balanced XLR. From Sub-Out / LFE-Out of
preamp, processor or other line-level source
Line-Level Input Sensitivity
100 mV mono
Line-Level Input Impedance
RCA: 10k ohms; XLR: 20k ohms
AC Voltage
120v (at 3,000 watts) - 50 / 60 Hz
240v (at 4,500 watts) - 50 / 60 Hz
(see note on Universal Input Power below)
Height, Width, Depth††62.2 cm x 60.4 cm x 57.8 cm
24-1/2 in x 23-3/4 in x 22-6/16 in
Diameter of Hexagonal Cabinet60.4 cm
23-3/4 in
Weight (unpacked)106.0 kg / 230 lb each
Finishes
Cherry, Piano Black, Black Ash
Manufacturers Published Measurements
N/A
Frequency Response
Max Output Before Compression
Spectral Decay
Group Delay
Waterfall
Spectrogram
Harmonic Distortion
Click the Methods button for the REW notes from each individual frequency
Measurement Methods
10 Hz
65536-point spectrum using Rectangular window and no averaging
Input RMS 88.2 dB
Distortion at 10.1 Hz, -26.4 dB FS based on 8 harmonics:
THD 9.7793 %
THD+N 25.4216 %
2nd harmonic 5.2699%
3rd harmonic 7.2533%
4th harmonic 1.7892%
5th harmonic 2.6473%
6th harmonic 1.5896%
7th harmonic 1.3173%
8th harmonic 0.5273%
9th harmonic 0.7090%
12 Hz
Input RMS 90.8 dB
Distortion at 12.6 Hz, -23.8 dB FS based on 8 harmonics:
THD 9.6250 %
THD+N 24.1308 %
2nd harmonic 6.0323%
3rd harmonic 6.4647%
4th harmonic 2.2967%
5th harmonic 1.9710%
6th harmonic 1.4001%
7th harmonic 1.3112%
8th harmonic 0.9123%
9th harmonic 0.8867%
16 Hz
Input RMS 96.9 dB
Distortion at 16.1 Hz, -17.8 dB FS based on 8 harmonics:
THD 11.8651 %
THD+N 30.0082 %
2nd harmonic 3.6300%
3rd harmonic 10.6023%
4th harmonic 3.3318%
5th harmonic 1.4110%
6th harmonic 1.0330%
7th harmonic 0.6611%
8th harmonic 0.5550%
9th harmonic 0.5396%
20 Hz
Input RMS 99.6 dB
Distortion at 20.1 Hz, -14.9 dB FS based on 8 harmonics:
THD 8.5693 %
THD+N 18.1309 %
2nd harmonic 5.7179%
3rd harmonic 5.9597%
4th harmonic 1.8268%
5th harmonic 0.7743%
6th harmonic 0.6952%
7th harmonic 0.5881%
8th harmonic 0.5100%
9th harmonic 0.4407%
25 Hz
Input RMS 103.8 dB
Distortion at 24.9 Hz, -10.7 dB FS based on 8 harmonics:
THD 8.9335 %
THD+N 14.9969 %
2nd harmonic 8.5627%
3rd harmonic 2.4922%
4th harmonic 0.4415%
5th harmonic 0.2562%
6th harmonic 0.0991%
7th harmonic 0.0563%
8th harmonic 0.0401%
9th harmonic 0.0442%
31.5 Hz
Input RMS 105.7 dB
Distortion at 31.6 Hz, -8.8 dB FS based on 8 harmonics:
THD 10.2233 %
THD+N 20.3871 %
2nd harmonic 10.0985%
3rd harmonic 1.5577%
4th harmonic 0.2215%
5th harmonic 0.1523%
6th harmonic 0.1005%
7th harmonic 0.1375%
8th harmonic 0.0681%
9th harmonic 0.0689%
40 Hz
Input RMS 109.7 dB
Distortion at 39.9 Hz, -4.8 dB FS based on 8 harmonics:
THD 7.8603 %
THD+N 17.7246 %
2nd harmonic 7.7971%
3rd harmonic 0.7755%
4th harmonic 0.3711%
5th harmonic 0.3086%
6th harmonic 0.2367%
7th harmonic 0.2003%
8th harmonic 0.1771%
9th harmonic 0.1629%
50 Hz
Input RMS 110.6 dB
Distortion at 49.9 Hz, -4.1 dB FS based on 8 harmonics:
THD 8.1011 %
THD+N 26.5220 %
2nd harmonic 1.9607%
3rd harmonic 3.3402%
4th harmonic 2.8839%
5th harmonic 2.9866%
6th harmonic 3.0711%
7th harmonic 2.8752%
8th harmonic 2.8626%
9th harmonic 2.7380%
63 Hz
Input RMS 110.9 dB
Distortion at 63.1 Hz, -3.8 dB FS based on 8 harmonics:
THD 7.3311 %
THD+N 28.4632 %
2nd harmonic 1.1413%
3rd harmonic 2.9864%
4th harmonic 2.7629%
5th harmonic 2.7031%
6th harmonic 2.6506%
7th harmonic 2.7529%
8th harmonic 2.6927%
9th harmonic 2.5941%
80 Hz
Input RMS 110.9 dB
THD 7.3311 %
THD+N 28.4632 %
Input RMS 88.2 dB
THD 9.7793 %
THD+N 25.4216 %
12 Hz
Input RMS 90.8 dB
THD 9.6250 %
THD+N 24.1308 %
16 Hz
Input RMS 96.9 dB
THD 11.8651 %
THD+N 30.0082 %
20 Hz
Input RMS 99.6 dB
THD 8.5693 %
THD+N 18.1309 %
25 Hz
Input RMS 103.8 dB
THD 8.9335 %
THD+N 14.9969 %
31.5 Hz
Input RMS 105.7 dB
THD 10.2233 %
THD+N 20.3871 %
40 Hz
Input RMS 109.7 dB
THD 7.8603 %
THD+N 17.7246 %
50 Hz
Input RMS 110.6 dB
THD 8.1011 %
THD+N 26.5220 %
63 Hz
Input RMS 110.9 dB
THD 7.3311 %
THD+N 28.4632 %
80 Hz
Input RMS 110.9 dB
THD 7.3311 %
THD+N 28.4632 %
