1 - 3 of 3 Posts
Do you have access to the proper sized surrounds from Paradigm or were you planning on using generic ones?
I am not sure which approach to use since I have never had to re-cone anything. If the first kit is a perfect match dimensionally, I can't see a reason not to try it. I would go for it. If it doesn't go well, we can help look for woofer replacements. If it does go well, you're back in business :T
1 - 3 of 3 Posts
