I am having an issue with my Parasound HCA-1205A. It powers on and plays fine, but after warming up for a few minutes the current overload protection comes on for channel one. This happens even if the amp it sitting idle with no inputs or speakers connected. The protection LED will flicker on and off a few times, then stay on. The other channels still play ok while channel one is in protection mode.
Internally, each channel has its own amp module, and they all share an I/O board along the back of the case. I switched a few of the modules around and from what I can tell, the channel one module and the I/O board at the rear are not causing the problem. At this point I have disassembled as much of the amp as I'm comfortable doing, and based on a couple of basic troubleshooting tactics, I believe the problem lies in the protection circuit (separate board between the main power input and the transformer, with some type of feedback from the individual amp modules). Visually this board looks ok. I did notice at least one component (a relay if I remember right) appears to have been removed and/or replaced based on the solder points looking different than the others on the same board.
Anyone have experience with the Parasound HCA amplifiers, or any insight as to what could be causing the protection to be activated on just one channel under these conditions? I'm comfortable replacing components on the circuit boards, but my ability to troubleshoot at the component level is limited. I have checked a couple of other forums for answers, but other owners seem to be experiencing this problem while playing at high volumes, rather than just sitting idle - i.e. the protection circuit is doing what it's supposed to do. I can remove the cover and post some photos of the internals if that helps.
