1 - 4 of 4 Posts
Those boxes are less than 6 cu ft and you are modelling 7 cu ft so you need to look at what can be achieved in a smaller enclosure. Plus you would still need to cut holes for the PR's anyway and when you remove the volume taken up by the PR's it is smaller again.
Are you modelling in WinIsd Pro or Beta? When I plug your files into WinIsd Pro the response drops very quickly from 200 Hz. Is this what you were after?
I am modeling with Pro. I thought it was weird too... but, here are the plots with the LMS Ultra 5400 Sealed, the 5100 sealed and vented, plus the previous PR setup with 1520 grams.... They all line up pretty close... I checked the parameters and they look good. Am I doing something wrong?
Don
1 - 4 of 4 Posts
