The issue I am having is that my subwoofer output is now very low with the miniDSP inline. Even adjusting the AVR gain from +2 to +10 it is very low. I am sure I just boogered up a setting somewhere. Any ideas?
Pretty sure I pressed the calibrate button on the spl function, which probably messed up the spl calibration. Maybe if I reload the calibration file it will readjust itself? Will be a week from Tuesday before I have time to play with it again.The UMIK is a calibrated mic, so as long as you are loading the calibration file into REW then REW is showing you accurate dB SPL! What exactly is the problem you are having?
Did you use only cutting filters? That’ll do it.The issue I am having is that my subwoofer output is now very low with the miniDSP inline. Even adjusting the AVR gain from +2 to +10 it is very low. I am sure I just boogered up a setting somewhere. Any ideas?
blitzer, I'm curious. Are you using MS or OSX?You are hitting on the same issue I have with the MiniDSP/UMIK-1. Even with NO filters, it reduces the sound too much. I have tried a lot of things including a Bump Box to change the voltage, opened up the MiniDSP to change the sensitivity jumpers, but regardless the output is diminished too much for me to use the MiniDSP. I did manage to get the curves flat with the MiniDSP at reference volume, but then bass is completely missing for movies…just gone. This is a subject that has been explored and is somewhat complex to tackle. Search these forums on MiniDSP gain samson s-convert.
Unfortunately, I have my MiniDSP sitting on the bench permanenly because of this.
Ugh I somehow knew you were going to say that..I tried OSX and REW was not working right at all.,,,switched to Windows and all was well.
I will run it without filters to see if it reduces output.You are hitting on the same issue I have with the MiniDSP/UMIK-1. Even with NO filters, it reduces the sound too much. I have tried a lot of things including a Bump Box to change the voltage, opened up the MiniDSP to change the sensitivity jumpers, but regardless the output is diminished too much for me to use the MiniDSP. I did manage to get the curves flat with the MiniDSP at reference volume, but then bass is completely missing for movies…just gone. This is a subject that has been explored and is somewhat complex to tackle. Search these forums on MiniDSP gain samson s-convert.
