I use 4 of these passive radiators in my Bang and Olufsen RL 60 re-design in place of their failed ABRs for a great modification with excellent bass reproduction.
They work in other applications as well, especially desktop speakers for computers and Ipod docks with amp/speaker combos needing the extra bass extension and they can be used in small mains and surround sound speakers.
Leveraging the best in Danish craftsmanship, but manufactured to be very affordable, these audio transducers are ideal for use in small surround sound systems, but can also be used in a wide variety of end user products and applications.
Coated paper cone and premium stamped steel chassis. This is a nice alternative to conventional ported systems. Cosmetically matches Peerless SDS 5-1/4" drivers like the 830941, 830887, 830879, and others. Popular replacement for Bang & Olufsen Redline ABR systems. *Fs: 23 Hz *Vas: 0.37 cu. ft. *Qms: 10.0 *Cms: 1 mm/N *Mms: 48 g *Rms: 0.67 Kg/s *Sd: 87 sq. cm *Xmax: 6 mm *Dimensions: A: 6"; 5-1/4" across flats, B: 4-5/8", C: 1-1/2".
Premium sculpted "pincushion" stamped steel chassis
Coated paper cone with rubber half roll surround
Use one or two radiators per woofer
Please visit my website for more information: http://www.speakerhobby.com/Peerless Tymphany 830880 passive radiator.htm
Photo #2 shows the foam gasket already mounted which makes for an easier installation.
The list price is $21.99. Your price is $18.00 ea. or 4 or more drivers @ $16.00 ea. Please place your order through my website.
