1 - 9 of 9 Posts
Cool PDF, I have not used metal, but It would look great I bet!
Many just use Guilford of Maine fabric, but the metal opens up some new possiblities - as it doesn't need to be pulled tight - in theory, you could make an entire panel with nothing but metal (bent to form tops sides and bottoms and the material inside.
basementjack,
Apart from asthetics, you may have noticed, it also slightly improves the absorption in upper-bass region. However, I am not sure about the availability and price for perforated metals though.
G
Looks like something in a perforated metal would be great! A whole lot better than cardboard for sure. Maybe a metal housing of some sort could be made into something that is a little more aesthetically pleasing too. Something with a little flare and class to make the little woman happy. Does such a beast exist? The perforate metal or steel bass trap I mean. LOL
Would wire mesh be a better alternative to the perf metal in this instance? May be a little bit cheaper and act in the same fashion? just a thought to some cost cutting alternatives...
Belleville Wire Cloth. Cedar Grove, New Jersey
Can probably find the mesh alternative on that site or something related.
Good Luck guys,
basementjack,
If you check it out a Home Depot or similar store it's very expensive. Same goes for McMaster Carr. It's typically more than $50 for a 3x3 sheet. You could punch or drill one yourself but would be very laborious and still pricey for the metal if bought new.
Several years ago, we were in a sales room that was built on the factory floor. They used a commercial pre-fab acoustic wall construction, that was perforated sheet-metal panels with acoustic fiberglass backing. That room had a very nice acoustic feel.
1 - 9 of 9 Posts
