I'm a newbie to all this. Planning to put together a home theater. Not as detailed and intensive as yours though......$$$$$. Looking to get started on it in the next week or so.
Questions:
Issues:
1: what effect do vaulted ceilings ( my rooom has ) have on picture quality, light throw from the screen reflecting? Paint Ceiling Black?? Velvet around screen or paint front wall black ?
2: I have windows in the room I am going to turn into a HT, whats the best way to block them out??
I would like it to be removeable what ever the fix is. I was thinking some sort of styrofoam block with a felt covering??? Any ideas??
3: Room paint and light reflection?? I read a few articles and they insist on dark flat neutral colors. You did a great job with yours, making it usable and liveable to be in when not viewing film. (not morbid)
Room info:
The room is 15' long, 15' wide and 8' tall walls - vaulted ceilings
Wood floors, light colored walls (a light yellow/green/white called pampis grass)
When house was built had the room pre-wired for a projector on ceiling and 7.1 sound
Limited Budget 1st Build (theres always future builds ) $3000 approx.
Denon AVR1912 875w (need to purchase) cost $550
Elite EzFrame Fixed Frame Screen Cinegrey 106" cost $400 or 126" $500(need to purchase)
Epson Powerlite 3010 (need to purchase) cost $1600
Projector mount (need to purchase) cost $300-500
Definitive Technology speakers (have)
Blue ray Player (have)
Cable Box (have)
Any input advice for room or needed equipment would be great.
Questions:
Issues:
Room info:
Cable Box (have)
