New woofer coming out from Mark Just wanted to let others know. Carbon Fiber cone Phase plug and much more useful at above 200hz than the UXL. This subwoofer from what I have heard was more geared towards SQ.
http://www.istonline.ca/mach5_phallus.html
Mark again has made another amazing product.
Features
Parameters
Fs (Hz) 21.8
Re (Ohms) 3.2
Qes 0.38
Qms 9.72
Qts .37
Cms (mm/N) 0.151
Rms (kg/s) 4.97
800 watts power handling
Mms (grams) 352.9
BL (Tm) 20.12
28mm Xmax excursion for maximum output
VAS (L) 224.3
Sd (cm^2) 1029.2
Lp (2.83v/1m) 93.8
Suggested Box Sizes
Sealed - 100L (3.5 cu. ft.)
Bass Reflex - 150L (5.3 cu. ft.)
EBS - 310L (11 cu.ft.)
Features
Parameters
Fs (Hz) 21.8
Re (Ohms) 3.2
Qes 0.38
Qms 9.72
Qts .37
Cms (mm/N) 0.151
Rms (kg/s) 4.97
Mms (grams) 352.9
BL (Tm) 20.12
VAS (L) 224.3
Sd (cm^2) 1029.2
Lp (2.83v/1m) 93.8
Suggested Box Sizes
