1 - 1 of 1 Posts
Friend of the Shack
Hi dlark.
Touch a battery across the speaker terminals. If the cones of each speaker move in the same direction, then they are wired correctly. Of course, you want to orient the battery in the same way each time.
You could also allow music to play with the sub only. If you still find it boomy, you'll know it has nothing to do with your main.
Good luck.
1 - 1 of 1 Posts
