1 - 3 of 3 Posts
I have a Philips HDTV Rear Projection 60PP93 5217 DPTV310. The convergence IC's were bad so I replaced the whole board (messed up the other one trying to just replace the IC's). Now everything looks good, but the only problem is the green convergence (which I line my red and blue to) is turned. It looks like someone took my tv and turned it on it's side at a 22 degree angle. I had sears come out to look at it and hook a signal bar generator up to it and align the colors including green, but he said that these tv's don't use those. He said that you have to buy a convergence chart and tape it to the screen in order to align the green. Is he right? Does anyone know how I can fix this dang thing? All colors can move vertical and horizontal. I can post pictures if need be. Please help!
V/r
Joseph
Plain ole user
You twisted the green yoke, likely by tugging on the wires. It needs to be straightened and if the geometry is decent for the red and blue use them as a reference for the green.
1 - 3 of 3 Posts
