Hi,
Got a Pioneer PDP-507XD, 50" plasma screen which stopped working on me. It turns on but will turn off and the main light will flash twice repeatedly.
I've surfed the net and there are references that the power supply board is faulty.
I can surf the net with the part numbers on the power board, also wondering if it's worth spending money fixing the unit or should I sell for spares.
Does anyone know if replacing the board would fix the problem?
I managed to get a hold of the service manual off the net and it recommends not to replace the power board, if it's faulty and a full TV replacement is needed!
Has anyone replaced the power board on the 50x range and can confirm this worked for them.
cheers.
cheers.
