Sorry mate the previous TS were for TS-W305DVC.... here are specs for TS-W306DVC. can u please re run your software. is it still 5 cu ft. Regret giving you wrong info..
THIELE-SMALL PARAMETERS
Model # TS-W306DVC Model
Nom. Nom. Dia.(In) 12 Dia. (In) 12
Qts 0,480 Qts 0.480
Qms 10,800 Qms 10.800
Qes 0,500 Qes 0.500
Fs[Hz] 32,9 Fs [Hz] 32.9
Vas[l] 51,76 Vas [l] 51.76
Vas[ft3] 1,828 Going [ft3] 1.828
Vd[l] 0,432 Vd [l] 0.432
Vd[ft3] 1,53E-02 Vd [ft3] 1.53 E-02
Sd[m2] 4,60E-02 Sd [m2] 4.60 E-02
Sd[ft2] 0,495 Sd [ft2] 0.495
Revc[ohm] DUAL3.0 Revco [ohm] DUAL3.0
Levc[mH]at 2000Hz 3.320(8Ω) LEVC [mH] at 2000Hz 3320 (8Ω)
0.826(2Ω) 0826 (2Ω)
Xmax[mm] 9,4 Xmax [mm] 9.4
Xmax[In] 0,37 Xmax [In] 0.37
Zmax[ohm] 139.20(8Ω) Zmax [ohm] 139.20 (8Ω)
34.83(2Ω) 34.83 (2Ω)
Bl[Tm] 18.570(8Ω) Bl [Tm] 18,570 (8Ω)
9.290(2Ω) 9290 (2Ω)
Rms[Ns/m] 2,589 Rms [Ns / m] 2.589
Mms[g] 135,27 Mms [g] 135.27
Cms[m/N] 1,700E-04 Cm [m / N] 1.700 E-04
Mg.Wt.[g] 2400 Mg.Wt. [g] 2400
Flux Density [Gauss] 7400 Flux Density [Gauss] 7400
Hag[mm] 10 Hag [mm] 10
Hag[In] 0,394 Hag [In] 0.394
Hvc[mm] 29 Hvc [mm] 29
Hvc[In] 1,134 Hvc [In] 1.134
VC.Diameter[mm] 55 VC.Diameter [mm] 55
Eff[%] 0,36 Eff [%] 0.36
SPL[dB] 89,0 SPL reduction [dB] 89.0
RMSPower[W] 400 RMSPower [W] 400
MMP[W] 1000 MMP [W] 1000
Sp. Displacement[l] 3,30 Sp Displacement [l] 3.30
Sp. Displacement[ft3] 0,117 Displacement Sp [ft3] 0.117
