1 - 3 of 3 Posts
I have a pioneer vsx-818 that wont power up. I found out that if you push tune+ and auto surr for 2 sec. it will tell you whats going on. It says "amp err overload". Is there a way to reset or does it require repair. I have solder skills if it a part that needs replaced. I just need to know what part it is. Thanks for the help
Burke
· Plain ole user
Disconnect the speakers and turn the unit off and back on. If it still occurs try a service reset, which will require the service manual. If that does not work contact a Pioneer servicer as the unit will need repair and they are seldom easy to fix if you are not very familiar with these kinds of units.
1 - 3 of 3 Posts
