1 - 9 of 9 Posts
I don't want a metal one, I want it in all plastic so I can still use my speakers. I am looking for an all plastic TRS 1/4" "dummy" headphone plug to stick in my Receivers to keep dust from contaminating the contacts. Does anyone know where I might find something like this?
Super Moderator
Not sure what a TRS plug has to do with speakers, but you aren’t going to find a plastic one. They don’t conduct electricity very well, so no one has a use for them. I see no reason why a standard one wouldn’t keep dust out of the jack. Or, why not just stick a piece of tape over the hole?
I am aware Plastic TRS plugs are not very conductive which is why I want one. I have plenty of metal 1/4" to 3.5mm adapters that I could use but when I plug them in to my receivers, it cuts the signal to the speaker. Using a plastic TRS plug would keep the dust out (headphone crackles) and it should allow the signal to keep flowing to my speakers when the headphones are not in use.
I have found reference to such a plug, but the forum post was from 2002 and the URL to the product page is no longer valid.
A plastic one would still cut out the signal on the headphone jack on the receiver as there is a micro switch inside the jack that is tripped when you stick the 1/4" jack into it, it will have nothing to do with it being plastic or not.
Discussion Starter #6 (Edited)
I know some headphone detection is software based. If I'm not mistaken, the headphone jack on my Yamaha and Integra work off a relay. Tape is so inconvenient. I'll have to test this out with a wooden dowel. And find a way to work around the switch, perhaps a 3/8 dowel will work for this purpose?
If any manufacturers ever read this- Maybe a rubber cap as you saw on the old yellow Sports Walkmans of the 80s and 90s would be much better? Perhaps a plug that goes in only partway or a spring loaded door like the one you see covering some toslink jacks. Or an electronic camera like shutter opens when you turn the equipment on and off.
Super Moderator
The only reason the Walkmans' had rubber caps was for waterproofing, not dust-proofing.
Can’t say that I’ve ever heard of dust “contaminating” headphone jacks. Is this something you’ve actually had a problem with? I suspect if it were an issue, manufacturers would have dealt with it decades ago. I have some components that are 20 years old, and the headphone jacks work fine.
Discussion Starter #8
Can’t say that I’ve ever heard of dust “contaminating” headphone jacks. Is this something you’ve actually had a problem with? I suspect if it was an issue, manufacturers would have dealt with it decades ago. I have some components that are 20 years old, and the headphone jacks work fine.
Not recently. But I have heard it before.
Super Moderator
How so? Just fold a tab on one end. It’ll come off and on easier than a rubber Walkman plug.
And find a way to work around the switch...
Software- or relay-based, they work the same way. It starts with a normally-closed switch contact arm built into the jack that breaks connection when the plug is inserted. There is no viable work-around, other than to simply avoid breaking the connection.
A search for “headphone jack dust” got this e-bay page with lots of options for rubber plugs. If this is for a 1/4" jack, you could also simply use those expandable foam ear plugs. Probably as inconvenient as tape or a rubber Walkman plug, but an easy solution.
1 - 9 of 9 Posts
