1 - 10 of 10 Posts
Im looking for a three way plate for the build im doing. all the ones i find are subwoofer.
Thanks Greg
Parts Express used to have full range plate amps that were two way, you might check there.
cool unless im over looking or dont know what im reading(<--- most likly) i didnt see them. let me look again
If you're looking for 3-way plate amps and can afford them, madisound sells the digmoda plates. In 2 way and 3 way with their own proprietry built-in DSP. Real nice but pricey.
TJ
does this sound like a good amp kit
Basic performance parameters:
Work: D class
Quiescent Current: 65mA
Efficiency: 90%
Rated output power: 2 * 100W
Frequency response: 20Hz to 50KHz
Operating voltage: AC12.5V to AC24V
Recommended supply voltage: AC20V-0-AC20V
Maximum output current: 8A
PCB size: (70 × 86) mm
what about class d audio? check out their website for a wide selection of items. plus I bet if you call the guy that runs it he could help you with a solution. he is very helpful.
1 - 10 of 10 Posts
