1 - 2 of 2 Posts
Hi!
I got this cal file for the RS 33-2055 and while I havent been able to setup up REW yet I would like to start taking some measurements. I found an excel page that you can enter the SPL and it gives you a corrected output and it seems there is a BIG difference between the new digital and old analog meter. For instance, at 20hz the new digital seems to only need +2.5db while the old analog was 7db! Am I doing this correctly?
Regards
If you downloaded the correct Excel Workbook for your meter from the Downloads page, you will be okay.
There is a difference between all three meters.
1 - 2 of 2 Posts
