H
HazePoker
·Guest
I have a Toshiba TDP 45T Projector.
I have a Onkyo S5100 Home Theater in a Box.
Problem: I can't get the projector to run through the DirecTV box and produce a clear picture?
Attempted Solutions:
-I have a RGB/R15 cable that goes into my projector (15 pin) that looks like a VGA on one end and the other end is R/Yb/YG (Component).
-At my previous home I had it hooked up to a Xbox, Time Warner Cable Box and DVD player and had no problems.
-I use the same cables and now (since I moved) the DVD works find and picture looks great.
-When I connect the cord to the DirecTV box the picture has a little saturation of green and there is a line that continuously goes up and down through the screen. Sometimes that picture will stay on, blink a few times and then the screen goes back to blue and it said the signal is unreadable.
-I HAVE direct connected to the DirecTV and it worked but now it does not.
-I know the cable is fine b/c it works with the DVD player just fine.
-I have opened up the settings on DirecTV to allow it to read/change to 480p, 720p, etc as they come into the receiver so it's not forcing it to accept one particular format.
Any suggestions or tips would be greatly appreciated! I'm lost...:scratchhead::scratchhead:
