Hello,
The following is a graph taken using REW. I am using a SVS SB12PLUS with a crossover at 80HZ. Main speakers are disconnected. Loaded correct Radio Shack Meter calibration and completed soundcard calibration which looked good (using Behringer UC 202). I check my AVR and made sure it was setup in stereo and all DSP/boosts/trims are shut off. I feel I followed all of the directions and need some additional advice. Thanks in advance for you input.
Why is the sub db level significantly higher than my target 75 db which was setup? It appears to following the curve at a higher db level.
What are your thoughts regarding the graph? I know I can play around with sub placement a bit? I also can smooth out the null a bit 27HZ by increasing the crossover to 100HZ on my AVR.
It also appears I have some noise in my PC soundcard with the steep increase at 18HZ after sub rolloff begins. Is this the case based on your experience?
Based on the graph...Is there a specific peak I should tame with my subs PEQ before running audyssey to further smooth out the response?
