1 - 2 of 2 Posts
Hi, I'm on my 3rd receiver, 2nd blu ray player and maybe a new tv soon trying to solve this.
I feel my Vizio e50-d1 might be the problem now. I've hooked BD players up directly to the tv with no problems. I've had just the receiver connected to the tv with no problems. The problem always comes when the BD player, Receiver, TV are all hooked up together. I've tried every combo of hooking up, turning on, inputs, outputs, it just always shows the blu ray splash screen for a second then starts flashing and says no signal.
I've tried 3 receivers and 2 BD players so all that's left is the tv. But it's weird that everything hooks up on it's own to the tv with no problems. I"ve also tried turning off any 'Auto' in the settings and updated firmware.
Please help, any ideas, is the TV pooched??!!
Thanks
A the Blu-player works when connected to the TV you could try going into the receiver video settings and changing it to source/direct or whatever your receivers terminology is. It could be the receiver is applying some video processing that your TV does not like. Apart from that have you tried different HDMI cables?
1 - 2 of 2 Posts
