1 - 7 of 7 Posts
I have opportunity to aquire some Polk rti 10's fairly cheap and am wondering if anyone has used one as a center channel lying on it's side. Any thoughts? It would obviously be a little overpowered as a center but would be matched perfectly to the a/b channels. Honestly, for the price I can get them for I can't buy the actual matching center(csi5). At the same time I don't want to use it that way if it's going to suck as a center.
Allot of people who setup dedicated Home Theaters use the same speaker for all of the front sound stage. I personally don't think you can have an over powering center. When I bought my speakers I bought the largest center in the series of speaker they had. My center has seven drivers and it is great. I say if your getting a good deal "jump on it". That is just my opinion.
The real problem
If there is one is where the sound waves are pointed from a tower vs a center. The cross over frequencies should have nothing to do with if it's on it's side or not. I'm am not expert, but I'm pretty sure I am correct. I would think that it will be ok. If it's not you can purchase a center and one more tower and you can use towers for your surrounds. That is just an option. I would consider the deal your getting on the speakers. I would wait for someone who has used a tower on it's side to give you their opinion, but I think it will be just fine.
Audition the speakers and lay one on its side at about the same height as you plan to use it to see if you can hear a difference or not.
My concern is that the rti 10 is a tower array, and I would have to lay it on it's side. I'm sure the crossover in a "center" is designed for horizontal use, but in a tower it's for vertical alignment. So what would a tower sound like laying down?
It was designed and engineered to stand up - Also, when you lay it on the side, your tweeter will
not be centered. It will be to the left or right, and you will miss out on a central image. Your choice,
try it if you want to.
1 - 7 of 7 Posts
