Hello folks.
I'm working on two different horn designs that will be barn burners and lease breakers. I started working on them in June so this is not a me to Danley thread. These two offerings are legitimate front loaded horns. Not tapped horns. They both when loaded into a corner have response that will be just under 100db/watt. They will both be using one TRIO12. Here is the difference. The big boy is here:
Little boy is here:
The astute among you will notice my definition of little and big has a bit of a twisted sense of humor to it. Once folded into a real box they are 16 cubic feet and 9.5 cubic feet.
I know am I crazy. If you have to ask then it isn't obvious! Here is why I'm so crazy. Here is the maximum SPL for each box.
BIG BOY
LITTLE BOY
The ripples in the response generally clear out into the room wash. So don't pay to much attention to them. Both boxes are long enough that if you EQ them they will not readily go into over excursion. Both posted max SPL are done in 1 Pi space. This is on purpose I understand that .5 Pi is a true corner. But few of us have a completely reflective concrete corner to put this into. If you do strap on another 3db on top. Both simulations are peaked out at 18mm X-max. This driver can do a clean 20 and over excursion to 22mm. So there is room for a bit more than 2 db more. Add in room gain and these boxes are almost flat to 20hz and 16 hz. So these are some real contenders. Definitly not available commercially. Oh did I mention that with 100 watts they can crack 120 db! muhhahahahha:R:R:R:R:R:R:R
Them that are interested vote. The one with the most votes is the one I build. This is a benevolent dictatorship after all!
Mark
Little boy is here:
BIG BOY
LITTLE BOY
Mark
