Just about done with my box and I do not have a good understanding of the different 'fill' materials and which I should use. I have the following
mal-x gen II - ep2500 amp
11.75 internal volume (this has bracing, port, and sub already removed - 14.28 cu ft total internal vol)
2 - 5.875 ID ports that are 35 inches long
Fairly large room - 25 X 16 X 8.5 ft
Would I gain anything in this ported enclosure by placing pillows/polyfill in at the 1 lb/ cu ft rate? Or should I just put some eggrate bedding material on the walls of the enclosure?
Thanks
Thanks
