1 - 9 of 9 Posts
Hi All,
I was taking some high level sweeps of my subwoofer yesterday and ran into a problem. At the beginning of each sweep, I was getting a pop or thud noise. At lower levels it was not an issue but when I hit over 105 dB at the LP it causes my clipping protection to engage on my Crown XLS1000.
Now, I don't believe this is a gain setting issue. After the pop happens and the clip protection has done it's thing, the measurement continues just fine at the higher level with no compression or clipping. I just don't get any data below about 30Hz because of the amp protection. Also, I know I've run sine waves at higher levels without clipping problems.
Any suggestions of how to eliminate this basically DC pop or thud?
Here is my equipment:
UMIK-1 calibrated by CSL
HTPC running Windows 7
Nvidia GTX 560 with HDMI out
HDMI in to Onkyo TX-NR809
Subwoofer out to Crown XLS1000 via RCA-XLR
Thanks,
Vann
Can you change the output of REW to match your playback device in windows (e.g. 48kHz, 16b)? Maybe the pop is from a reconfiguration of the sound codec in your 560.
Hmm, my windows sound says its configured for 16-bit 48 khz and REW is at 48 khz
Hi All,
Vann
Are you making a sweep at 105 db,85 db is better.
Maybe you make it clip because of the high volume level
Thank you but the sweep is not to determine frequency response at nominal level. I'm attempting to find the maximum clean SPL of the system.
I also do not believe I am clipping due to amp gain. There is a noticeable "pop" that happens at the start of the sweep that prematurely clips my amp.
I don't think I'm using ASIO. Perhaps I should be. I'll have to check this tonight when I get home.
Tonight I tried ASIO. Seems like it may have fixed the popping noise issue but I was unable to take any high level sweeps to confirm. It will likely be the end of the week before I can do so...
I noticed that within J River that there is a Pause that can be initiated before any audio is sent from the HTPC to your Onkyo. I wonder if there is such a setting within REW.
1 - 9 of 9 Posts
